vcProductNeedFeedMatch
vcProductNeedFeedMatch is created when product matcher matches a need and a feed with each other. vcProductNeedFeedMatch stores the properties of the mached need and feed, and controls the state of the match.
| MatchedFeed | vcProductFeed | R | Gets the properties of the matched feed. After a match has been disposed, the value is None. |
| MatchedNeed | vcProductNeed | R | Gets the properties of the matched need. After a match has been disposed, the value is None. |
| SelectedProcessFlowInfo | vcNextProcessFlowInfo | R | Gets the flow info that was selected in the Feed-Need matching process. |
| State | vcProductMatchState | R | Gets the state of the match. |
| dispose | None | None | Disposes a completed or cancelled match, so that the product need and product feed objects can be reused for another match.See moreChanges the state to Disposed and sets the values of matched need and matched feed to None. If dispose is called from within a state change event handler, disposing is delayed and will only be executed after all event handlers have been called. Dispose can only be called when the state is Finalized, Cancelled, or Disposed. If the State is already Disposed, dispose does nothing. Exceptions: TypeError: When match is not in cancelled or finalized state before disposing. |
| finalizeMatch | None | Optional Keyword[receivingNeed = vcProductNeed] | Sets the match state to Finalized. Normally, done by the need owner in vcProductNeed.OnMatched event handler.See moreParameters: Optional: receivingNeed (vcProductNeed): Can replace the MatchedNeed if a value is given. |
| setOnNeedOrFeedDead | None | Callable OR None function | Sets the callback function that is called when the value of either the matched need or the matched feed is set to None.See moreParameters: function (callable): The function to call when the event is triggered. |
| setOnStateChanged | None | Callable OR None function | Sets the callback function that is called when the state of the match changes.See moreParameters: function (callable): The function to call when the event is triggered. |
| tryCancelMatch | None | None | Attempt to cancel the match. A match cannot be cancelled after the match has been finalized. |
